BikeBandit
Old 02-22-2007   #1 (permalink)
My 03 has a PCIII and a Scorpion exhaust on it. It runs fantastic, but between around 9k and 11k, it definitely pings at 2/3 throttle. Full throttle seems fine. Ive looked at the maps on the laptop, added fuel, etc, and still no joy. Does anyone know of a place that has the maps? I went on the Dynojet website, and their maps are definitely fuxored....causes jumpy low RPM starts on my bike.
Could be the 91 gas around here causing the pinging, thats for sure.
Thanks guys,
Alex
dravis is offline   Reply With Quote
Old 02-25-2007   #2 (permalink)
Favorite Bike: All
wills's Avatar
I don't know about the 03 600cc, but on the 1050 and 2.3 Triumphs you need to get the O2 connector from Power Commander or you can't keep the A/F under control. I found this out when my dealer wrote a custom dyno map for my Sprint. With the O2 sensor out of the equation, the bike runs great and makes more power. Call Power Commander tech support and see if you need the part. You might need to get a dyno tune written to get the bike to run at it's best.
Spence
Freedom Cycle Reno, NV
http://www.freedomcyclereno.com/
wills is offline   Reply With Quote
Old 02-27-2007   #3 (permalink)
merdock
i bought a powercommander for a tt600 need a map for it any ideas
Old 02-27-2007   #4 (permalink)
Official Leathers Tester
Favorite Bike: Very fast 675
Will's Avatar
Extra Motorcycle: A couple of 'em
What year of TT600? They were different in 2000 and 2001.
Will
SponsorHouse profile
Old 02-28-2007   #5 (permalink)
Rik
Favorite Bike: Speed Four
Rik's Avatar
Can't help with the map but I can confirm that the TT600 doesn't have a O2 sensor!
Rik is offline   Reply With Quote
Old 03-02-2007   #6 (permalink)
my bike was built 10/02
03 model
Alex
Old 10-15-2007   #7 (permalink)
Newbie
i have the same problem
i have a 2006 955i it is bogging i install the power commander it idles better but stil boggs out do you have a map for my bike? thanks Vick
daytona955i is offline   Reply With Quote
Old 10-15-2007   #8 (permalink)
Will's Avatar
03 model
Alex
So that means there is no official Triumph map for an open can. Richen up the fuel idle trim- it should help with the jumpiness at low rpms. I am guessing they monkeyed with the ignition advance a bit for some reason. The other possibility is carbon deposits in the engine causing raised compression. Try running a whole lot of injector cleaner through your engine. I have heard of running just a bit of kerosene or diesel in the fuel to clean things out, but I am not sure I would try it on an injected bike.
Will
Old 10-17-2007   #9 (permalink)
Favorite Bike: '06 Triumph Speed 4
If it's possible to control timing with the PCIII definitely reduce the timing advance in the problem areas.
I have a PCIII that I haven't installed because of a lack of good maps - I've heard a few times that the ones from the site are junk.
Lots of places do dyno-tuning for Power Commanders - finding someplace local and having a map made for your bike would lead to the best running, but it ain't cheap (whereas I am ).
GL with it and let us know if you find a fix.
Beer is proof that God loves us and wants us to be happy. -Benjamin Franklin
rustbucket is offline   Reply With Quote
Power Commander MAP-Sprint RS smwoods Sprint Forum 0 11-10-2007 04:26 PM
t2006 riumph 955i power commander map??? daytona955i Modifications & Workshop Talk 0 10-15-2007 10:48 AM
Power Commander map for TT600 with yoshimura rs-3 wileytt Triumph SuperSports 0 07-03-2007 02:42 PM
2000 Sprint RS power commander custom map. rocketrich Sprint Forum 10 04-18-2006 01:03 AM
Power Commander Map Spacecom Tiger Mods & Bolt-Ons 21 01-11-2005 04:15 PM
