Motorcycle.com
Old 07-26-2003   #1 (permalink)
I lost both of my Speed Four oem Bridgestone tires within a ten-day period to nails and screws in the road. Luckily, I was able to plug one and pump it up at home and the other at four or five gas stations on the way home.
Now I want to add a cigar lighter-type electrical outlet to to run a little compressor I have. I prefer the compressor to CO2 bottles.
Are there any leads available or will I have to splice in somewhere?
Thanks,
RR
Old 07-26-2003   #2 (permalink)
Thanks,
RR
Old 07-26-2003   #3 (permalink)
Thanks,
RR
Old 07-26-2003   #4 (permalink)
Favorite Bike: Very fast 675
Will's Avatar
I don't think Triumph designed the wiring harness for that kind of installation, but you can put leads from the battery. I have a heated vest that uses leads directly attached to the battery terminal. There is a hole in the frame on the left side that is a perfect place to route the connector from under the seat. The heated vest connector is probably different from your compressor's plug, but you can splice wires on the lead without cutting up your bike's wiring harness. There is no problem that I am aware of related to that kind of installation.
Will
Old 07-26-2003   #5 (permalink)
Will's Avatar
Will
Old 07-26-2003   #6 (permalink)
Will's Avatar
Will
Old 07-26-2003   #7 (permalink)
Thanks, Will. That's about what I suspected. Another opportunity for me to go out in the garage and self-educate/self-destruct. I can never leave well-enough alone.
Cheers,
RR
[ This message was edited by: ITCHIN2 on 2003-07-26 19:11 ]
Old 07-26-2003   #8 (permalink)
Cheers,
RR
Old 07-26-2003   #9 (permalink)
Cheers,
RR
Alternator leads bonnebill Classic, Vintage & Veteran 16 05-24-2007 08:32 PM
HT leads? vigneron Hinckley Classic Triples 2 05-06-2007 03:44 PM
electrical leads ender Triumph SuperSports 0 04-04-2007 04:50 PM
Plug leads Wavey T3 Sport / Touring Forum 11 03-29-2006 05:28 AM
Ht leads Wavey Modifications & Workshop Talk 1 01-20-2006 12:50 PM
