Looks great! Removing the cowl really helps. Did you put some sort of back on the instruments to replace the cowl or is that just how it normally looks?
=Z=
"Life is a tale told by an idiot..."
On 2007-01-18 18:24, kubihibi wrote:
[On these bikes you will NEVER see the mechanical top speed because of too much wind resistance. Going to a 3.27 ratio from a 3.0 does not bring the mechanical top down far enough to meet the achievable top speed. Or if it did, I havent noticed yet. Fastest I've been since the sprocket swap is 128.
Sure, but you chose to quote me, & what's the relevance to my comment?
All right, you two, up against the wall!
I don't know what you want but you should know I've killed a lot of old people in my time.
And I'm not above doing it again.
