Old 01-16-2007   #1 (permalink)
Favorite Bike: Street Triple
Pancho's Avatar
Other Motorcycle: Aprilia RS125SP modded
Extra Motorcycle: C90, CB350
hi there just picked up a '00 TT600 as my first big bike and so far i love it, but im not getting on that well with the fuel injection, it feels very glitchy, ive heard this complaint bout em before but was wondering if there were any fixes for it. also at some point id like to get a Road Legal exhaust system and was wondering wat systems work best with the triumph 'sports' tune? cheers
2007 Triumph Street Triple w. Arrow cans and D675 shock
2000 Triumph TT600-sold
1997 Aprilia RS125 SP
1991 Honda CB350S
1985 Honda C90
Pancho is offline   Reply With Quote
Old 01-17-2007   #2 (permalink)
Rik
Favorite Bike: Speed Four
Rik's Avatar
Hi Pancho & welcome.
Apparently the early TT can be a bit sensitive at the bottom end. Some of it can be dialled out by getting the dealer to load a FI map (called a 'tune') from a later model and careful setting of the idle CO.
You can load tunes, create your own and a whole lot more with a piece of kit called Tuneboy
Tuneboy main site
Tuneboy UK
The other option is a power-commander.
Other members with TT experience who post here will be able to give you more detailed advice about best tunes for the '00 TT. Also try the search function as there will be previous chats about it.
Enjoy the ride and post some pics!
Rik is offline   Reply With Quote
Old 01-17-2007   #3 (permalink)
Official Leathers Tester
Favorite Bike: Very fast 675
Will's Avatar
Things to check- what map is in it? If it has an updated map, that helps. If you put the 2002 and later map into it, that helps more. Make sure the throttle bodies are synched. That can cause poor running, as can a too lean setting for the CO. If all that doesn't make it work like you think it should, then check the IAC valve and stepper motor. Those were ongoing problems five years ago, but most have been fixed. If your bike has very low mileage, then maybe it hasn't.
After all that, there will still be a bit of throttle snatchiness. It is fuel injected, and every fuel injected bike I have ever ridden has a bit of that.
Will
SponsorHouse profile
Old 01-17-2007   #4 (permalink)
Pancho's Avatar
its a 2000 model, with 4000 miles on the clock and as far as i know it has the latest tune in it, and the idle CO has recently been checked, but i'll hook it up to the actia as soon as poss. i noticed the throttle cable had quite alot of play too so i'll take that out. i'm really gutted the weather is so *****/dark. im gagging to go and learn to ride it well, it feels like its got so much to give. its also got Metz Renntec sports tyres on which dont feel too ideal for wet weather
1991 Honda CB350S
1985 Honda C90
Old 01-17-2007   #5 (permalink)
Rik
Rik's Avatar
Pancho - be careful when taking the slack out of the throttle cable. You need some slack as it will get taken up then you turn the bars. If there is not enough slack then when you turn the bars the bike will accelerate.......
Old 01-19-2007   #6 (permalink)
Favorite Bike: 00 Speed Triple (Black)
Catenaccio's Avatar
Other Motorcycle: 03 Speed Four (Tangerine)
Extra Motorcycle: 02 CBR1100XX (Silver)
From what I've read, the tune in the 00's was suspect. Other than that, it's a great bike.
Catenaccio is offline   Reply With Quote
Newb with ??'s HookEmHorns Sprint Forum 24 10-25-2007 11:26 PM
Newb Questions Dale Franks The Rocket Science Forum 10 09-12-2007 01:47 AM
newb high score photo thread-for the newb in all of us jrussell6 Speed Triple Forum 17 12-12-2006 02:25 PM
newb - first ride natec Twins Talk 18 05-01-2006 09:46 AM
another newb question FuryFour Triumph SuperSports 2 04-10-2006 06:36 AM
