Ldogdotcom is right there will always be some stretch as the steel wire is put under tension, it will also "try" to unwind a bit. However IMHO more usually there is compression in the cable outer (which gives the same effect of reducing the amount of action that you get when you pull on the cable). This is the same in any use of Bowden cables: Snow mobiles, tractors, boats, bicycles, cars or bikes.
The cable outer is a spiral of wire supported in plastic & fibres. Outer cable compression can occur whenever the cable run bends so the spiral opens up on the outside of the curve & has gaps in it. It is more likely if the cable has sharp bends or kinks, if the load being pulled by the cable is high (brakes or clutches) and when the supporting plastic & fibres get hot so holding the spiral less tightly in place.
For this reason most cable companies I have found in US & UK offer so called "non compressible outers" to reduce this effect in heavy duty applications. These are heavier duty & sometimes use square wire -I once found an old cable with a twin spiral of trapezium cross sectioned wires.
The easiest way of spotting cable outer compression is if the cable twists or flexes as you pull on the lever. They all do a bit, but after a few years you get a hunch about what is acceptable and what is "too much".
IMHO tHis was all much more critical on old european bikes as some had appaling clutch leverage and rubbish cables so the lift all but disappeared when you pulled on the lever.... and then the linings would begin to heat up & swell taking the rest of hte lift with them!
However Trispeed I dont know about your bike - my S4 has a poor clutch lift a very hot engine and a weak cable. So there is a slight reduction in lift with a hot engine which worsens the low speed gearchange. On my bike this effect is much reduced with a heavier duty clutch cable (like the venhill one). I notice Triumph put a hydraulic clutch in the D6 whcih gets rid of the problem - until the hose or seals start to bulge...
Still each to their own
Jon
