Coolant level is an odd subject, since the bike will find its own level over time. After it settles on how much coolant it really wants, you should not see any coolant or oil use at all. I just turned over 32K miles, and it uses no oil or coolant.
If you fill the coolant to "max" while the engine is cold, it will overflow. It doen't overflow until the bike is stopped, for some reason. If your bike is like mine, it will end up with a cold coolant level a bit below "min" and the coolant will rise up to just below "max" when very hot. Oil level should never vary.
Will
SponsorHouse profile
