The rubber diaphragm is designed to follow the fluid level down and is perfectly normal. It has nothing to do with the mushy feel of the brakes, that is a separate issue re: air in the brake lines. When you fill the reservoir to the full level, simply push the diaphragm back into it's highest level.
