Trident-Exhausts.comAdvanstarMotorcycleShowsMotorcycle.com
BikeBandit
Old 09-28-2006   #1 (permalink)
crowbay
Oh no, Bypassed the airbox and it is still smoking. The bike has been dyna tested and the compressions tested. All is perfect. It only does it intermittently but you can hardly see behind the bike it smokes so bad at times when it happens. Really thick blue white smoke. Then other times it is just a puff of blue. It will go up to fifty or so miles with no sign of it. Then do it 3 or 4 times over about 10 miles. Seems to be more predominantly at low speed. Does anyone have any more suggestions? Could it be a valve stem seal I wonder??
Old 09-28-2006   #2 (permalink)
does it ever smoke at startup for maybe 5-10 secs then clears up? does it smoke when you close the throttle and let the engine brake the bike like when taking an off ramp? if so those are sure signs of a worn valve guide. if you have smoking under hard acceleration, then its rings. if its smoking intermittenly with no predictable pattern i would say you are getting oil in through the intake somehow.. i would also check the oil and the coolant to insure they are not mixing, thats bad..
"when i let off the throttle it gets all squirrely, so, i just stay on the throttle.."
Joe275 is offline   Reply With Quote
Old 09-28-2006   #3 (permalink)
Also check to see if your oil isn't overfilled. Check it with the bike level and vertical. If the oil level is set with the bike on the sidestand, it will be very overfilled.
Joe-Dirt is offline   Reply With Quote
Old 10-01-2006   #4 (permalink)
Here's a picture of my bike. I just started it up. In the beginning of spring when it's not very warm yet.
Clicky
This seems to be normal, the smoking stops as the engine warms up, but when cold it smokes
Nelli is offline   Reply With Quote
centrifugal breather aka oil in airbox - out of warranty whoa Twins Technical Talk 13 11-15-2007 07:55 AM
Bare Steel Tank - To Seal or Not To Seal? GParks Twins Technical Talk 10 07-08-2007 10:00 AM
Can't find Airbox breather tube?!? Jack_T_Bird Hinckley Classic Triples 7 04-19-2007 04:43 PM
breather seal on new 955 motors nortoncharlie Modifications & Workshop Talk 2 05-24-2006 12:45 AM
Oil blowout from the crankcase breather(?) to airbox whoa Club Cafe 3 04-04-2006 05:12 PM
