you dont want to move your foot any closer, remember there are no fairings which means hot engines are not good to be touching.
however, if you must, youd have to find an aftermarket shift lever because the current was not intended to move inward, just up and down.
i havent needed to adjust the lever on the triumph, but if its anything like my kaw, the lever has to be set EXACTLY otherwise it wont fit.
hope that helps
"If you are not living on the edge, then you're taking up too much space."
