slipping between 5th and 6th gears - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Old 07-14-2004, 10:44 AM   #1 (permalink)
Lateley, on the first shift cycle on a ride, the transmission will slip a bit on the shift between 5th and 6th. It is like the clutch is disengaged, even after I release the lever, and then it slips a bit, and finally drops into 6th. The engine revs high, and sounds like im a newby every time this happens. I am worried that this isnt good, but it only does it on the first attempt to shift into 6th, then it is fine after getting warm.
Live and let live
punisher is offline   Reply With Quote
Old 07-14-2004, 11:15 AM   #2 (permalink)
Official Leathers Tester
Favourite Bike: Very fast 675
Will's Avatar
Have you checked your clutch lever adjustment? Does it clunk badly when you do get it into 6th?
Will
SponsorHouse profile
Old 07-14-2004, 11:22 AM   #3 (permalink)
Will,
No clunk, but it is like the clutch isnt engaging right away when I let the lever out. Like a slipping as if I was feathering the clutch, then it gently pops into gear, after revving like mad of course. Only on cold first shift cycles though
Live and let live
Old 07-14-2004, 12:44 PM   #4 (permalink)
Maybe the clutch is sticking, but the lever fully extends when released. If it is sticking, it is inside the case.
Live and let live
Old 07-14-2004, 03:48 PM   #5 (permalink)
Will's Avatar
If you have the cable adjusted too tight, it will have a similar effect. Try backing off the adjustment a little and see what happens.
Will
Old 07-14-2004, 05:33 PM   #6 (permalink)
will give that a try, although it seems like there is plenty of slack. Seems like a "sticky" clutch. Like the plates stick then release after the lever is released.
Live and let live
When to shift into 5th and 6th gear on Trophy VTXED Trophy 6 10-27-2007 12:11 AM
5th and 6th misses are really getting to be aggravating 4N099 Sprint Forum 26 09-30-2007 11:27 AM
Miss Shift between 5th & 6th Blockhead Tiger Workshop (archive) 5 08-07-2006 07:25 AM
Slipping gears, false neutral...***??? rigby Hinckley Classic Triples 11 05-10-2005 11:02 AM
jumping out of gear 5th - 6th Sprint Forum 6 10-26-2004 08:59 PM
