The SkyKing kit is great if I'm doing a tail chop, but doesn't work for my undertray
LOWEY - Hello good to have you back!
With the rsend, did you just drill two holes in the lip and bolt it up? Need any bracing on the inside of the tray to spread the load or just a couple of washers?
Totally agree with your comments about indicators:
<UL>
<LI>The integrated tail light & indicator look is sooooooooo clean, but just wasn't bright enough for me in daylight.
<LI>Flush mounted ones would certainly look neat but as the lense is pretty much pointed to the ground, again I'm not too sure about visibility & might be a problem come MOT time
<LI>Conventional mini indicators are certainly the easiest route and I'd probably cover over the wiring with some duck tape, but I think I'll lose some of the effect of having the undertray in the first place.[/list]
Just found the thread with the Yellow Speed Four you mentioned
Yellow Speed Four with undertray and flush indicators
Trouble is the guy that did the mod no longer posts here. Also, If I decide I don't like it, it's too late once I've cut the holes out ! :hammer:
uke:
