Old 09-06-2006   #1 (permalink)
commando
My low beams seem to blind the car in front of me and the hi beams show me the side of the road but not the road in front of me. The only way I get the road in front of me and the side of the road lit is by holding the pass button. Also, Are there any easy upgrades for bulbs brightness with out going over the recomended wattage?
Old 09-06-2006   #2 (permalink)
Yes. The Speed 4's headlights suck.
The best bulb for actual brightness at stock wattage is the sylvania silverstar. good bulb.
FullRunSilviaKs is offline   Reply With Quote
Old 09-06-2006   #3 (permalink)
The brightness of the headlights do suck, I put in PIAA's which make it a little better but not that great. As far as where they are pointing(mine were the same as yours) they need to be adjusted. My dealer actually knew about before I ever said anything to him and he said all S4 headlights are out of whack from the factory. All you have to do is stand in front and grab hold of the lights and rotate them down. It will be a little tough but they will click to the next notch. if you are worried you will break something you can lossen the bolts to adjust/remove which are on the bottom of the bracket that is between the lights. Good Luck :-D
Dirt286 is offline   Reply With Quote
Old 09-07-2006   #4 (permalink)
Loosen the hex bolt and tilt up the headlights one click. Thats what I did and it worked wonders. Though they still are not the best.
jared26jlvigil2 is offline   Reply With Quote
Old 09-07-2006   #5 (permalink)
err............ i was reasonably satisfied with my lights!!!!
have the relays under the seat for both lights on dip, beautiful illumination on full beam- as tested during numerous silly o'clock shift starts.
sorry! :razz:
johnnycactus is offline   Reply With Quote
Old 09-07-2006   #6 (permalink)
commando
[/quote]
Clockwise or counter?
Old 09-07-2006   #7 (permalink)
Favorite Bike: My 955 Daytona
doodledog's Avatar
Other Motorcycle: anything I can get.
the headlight adjustment is detailed "how to do it" in the owners book that comes with the bike. I find the brightness OK with the standard bulbs but they blew after about 1000 miles now have Zenon bulbs which are even better.
I went to a restaurant that serves 'breakfast at any
time'. I ordered French Toast during the Renaissance
http://stickerchick.com/images/AD455-th.jpg
doodledog is offline   Reply With Quote
Old 09-07-2006   #8 (permalink)
Favorite Bike: Speed Four
i've tried dozens of times now to adjust these things better...it can't be done on my bike!
i did put in the silverstar bulbs and it was like night and day difference.
VR6+12psi
05 S4
mode12 is offline   Reply With Quote
Old 09-07-2006   #9 (permalink)
Favorite Bike: Speed Triple
Catenaccio's Avatar
Other Motorcycle: Speed Four
Extra Motorcycle: CBR1100XX
Buy Silverstars and then have someone sit on the bike as you adjust the headlights at night. I set mine up for long distance on high beams. If I blind an oncoming car or truck on low beams, too bad. At least they can see me.
Catenaccio is offline   Reply With Quote
Old 09-08-2006   #10 (permalink)
commando
Used bike = no manual.
I am going to order the silverstar's. What size and wattage on the bulbs.
YOU GUYS SUCK S32k1 Speed Triple Forum 16 12-07-2006 07:49 PM
It runs like suck... 05Truxter Club Cafe 12 06-21-2006 03:53 PM
choppers suck SickBoy Twins Talk 17 10-22-2005 04:31 AM
Do tigers suck? Tiger Chat 23 09-23-2004 02:50 AM
Sprint S/T's SUCK!!!!!!!!!!!!!!!!! Sprint Forum 25 05-05-2004 10:35 AM
