brake pad question - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com Classifieds!Honda Powersports
Old 09-04-2006, 07:17 PM   #1 (permalink)
is it easier to pull the front wheel off or the calipers when changing brake pads?
thanks,
-Andrew
burgessa23 is offline   Reply With Quote
Old 09-04-2006, 07:38 PM   #2 (permalink)
IMHO calipers.
If you have a good frontwheel stand it is probnably better engineering to pull the wheel (and not disturb the delicate bits) but unless you lie on the floor (with a d_a_m_n good torch) you can see and clean the piston & caliper assembly easier if it is off.
Jon
[ This message was edited by: lcjohnny on 2006-09-04 17:39 ]
Old 09-04-2006, 08:46 PM   #3 (permalink)
on a sp4/tt600 you don't have to take the calipers or the wheel off, just take out the cotter pin and then the bolt that hold the pads in.
rockhopper1998 is offline   Reply With Quote
Old 09-05-2006, 03:50 PM   #4 (permalink)
True but I still like using the old toothbrushes to get the crud off the piston sides. Hoping to reduce the damage to the seals when I push them back in behind thick new pads.
And they have to come off as I haven't found a brush curvy enough to clean a 4 piston caliper while it is still on the bike.
Jon G
brake pad issue daaman Speed Triple Forum 4 07-10-2007 06:10 PM
Brake pad replacement question climbbike Sprint Forum 2 06-07-2007 06:32 AM
Brake Pad(s) PaleForce Twins Technical Talk 10 05-13-2007 01:12 PM
Brake pad replacement question NotSoFast Sprint Forum 4 05-01-2007 11:15 AM
Brake Pad Help drkside Club Cafe' 2 03-27-2007 01:09 AM
