tt600 front tyre.. - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com Classifieds!New BonnevilleHonda Powersports SportbikeTrackGear
Old 08-31-2006, 09:14 AM   #1 (permalink)
xdvst8x
what size is the front tire alan key ?
Old 08-31-2006, 10:57 AM   #2 (permalink)
Official Leathers Tester
Favourite Bike: Very fast 675
Will's Avatar
17 mm, if I remember right.
Will
SponsorHouse profile
Old 08-31-2006, 02:07 PM   #3 (permalink)
boyscout
Yep. 17mm
Old 08-31-2006, 04:41 PM   #4 (permalink)
xdvst8x
thanks!,
i have to replace the speed sensor... is this a common thing?
will it hurt the motor if the ecu doesnt know how fast its going?
oh yeah and.. what color is the yellow tt600? im trying to find the paint code so i can redo the fairings...
[ This message was edited by: xdvst8x on 2006-08-31 14:42 ]
Old 08-31-2006, 04:57 PM   #5 (permalink)
boyscout
OK one a time:
1. Personally I've never heard of anyone else having to replace the speed sensor.
2. Looking in Tuneboy I can't find anything in the ecu map that needs to know your speed.
3. Isn't the all yellow bike a different paint to the yellow and black? - Also aren't the paint codes given on the factory site?
Boyscout.
Old 08-31-2006, 05:03 PM   #6 (permalink)
xdvst8x
there are alot of different types of yellow on the website.. i dont know which one mine is.. its not yellow and black.. its a 2001 all yellow...
and when im riding.. my speedo says 10, 13, 30, 10 .. it doesnt go above 30mph.. and it jumps around no matter how fast i go..
Old 09-01-2006, 11:40 AM   #7 (permalink)
Will's Avatar
Speedo sensor failure is pretty much inevitable. I got through something like three of 'em over the years. The way it works is a magnet that hooks to a couple of tabs on the front wheel hub. If you take it all apart and clean it, it may work for a while longer, but the magnet eventually just deteriorates. It is a part that is common to all Sagem injected Triumphs, as far as I know. It is the same on my brother's Speed Triple, anyway. The ECU doesn't know or care how fast you are going.
The paint color on a 2001 TT600 is called Racing Yellow, and it is almost identical to a Chevrolet color called Millenium Yellow.
Will
Old 09-01-2006, 01:26 PM   #8 (permalink)
Favourite Bike: 07 Daytona 675
Other Motorcycle: 04 Yamaha YZ450f
Extra Motorcycle: 00 Buell X-1 Lightning
Yeah, the speedo thing sucks.
There is on on Ebay right now. The ones off the speed triples, speed fours, sprints, and all daytona' s(till current I think) are the same. make sure it's one of the newer non-600's if you go that route.
I think it's 2000 that they switched to the 5 lug brakes and different front wheels.
Creativity is only undetected plagiarism. - Mark Twain.
x1wagner is offline   Reply With Quote
Old 09-03-2006, 02:39 PM   #9 (permalink)
The paint codes
http://www.triumph.co.uk/uk/2046.aspx
ukilme is offline   Reply With Quote
Any one else Put on a Smaller Front Tyre? Moggy Twins Technical Talk 2 10-07-2007 01:24 AM
Front tyre question pomallon Tiger Workshop (archive) 18 04-12-2007 02:11 PM
Front tyre Rocket-tre The Rocket Science Forum 2 11-05-2006 06:39 PM
new front tyre bear640 Twins Technical Talk 4 09-29-2006 04:02 PM
TT600 Tyre pressure - HELP oxon_tt Triumph SuperSports 5 01-30-2006 12:09 AM
