startng problems - Triumph Forum: Triumph Rat Motorcycle Forums
Old 08-29-2006, 03:13 PM   #1 (permalink)
ok for about a month now i have had a hard starting problem on my 01 tt. you will crank on it for about 1 minute off and on and then it will start idle low and then come up to full idle.
i have replaced the fuel filter, plugs and air filter. the only mod is a new pipe.
i want to go on a long ride next week on my vacation but am affraid to. the closest triumph dealer is 200 miles away.
HELP!!
[ This message was edited by: midnight on 2006-08-29 13:14 ]
a baby seal walks into a club
midnight is offline   Reply With Quote
Old 08-29-2006, 03:40 PM   #2 (permalink)
Official Leathers Tester
Favourite Bike: Very fast 675
Will's Avatar
Sounds like a pinched vent hose or out of kilter tip over valve to me. If all else fails, open and shut the gas cap.
Will
SponsorHouse profile
Old 08-29-2006, 09:07 PM   #3 (permalink)
nope i took off both vent hoses to test that theory.
ok when i got home i went out to start it to go to the store. IT WONT START AT ALL.
it will drank and every once and a moment pop out the pipe. full tank of gas fuel pump priming and still nothing.
going to put in a new set of ngk plug tomorrow
Old 08-29-2006, 09:25 PM   #4 (permalink)
Will's Avatar
Does it have a new battery? What about a look in the airbox- is there oil in it?
Will
Old 08-29-2006, 09:32 PM   #5 (permalink)
batt is about 4 month old. the air box does have some oil in fue to a lay over about 2 month back. now that i think about it thats about the time this all started. what could cause the hard start. i cleaned most of it all out.
[ This message was edited by: midnight on 2006-08-30 06:45 ]
Old 08-30-2006, 11:02 AM   #6 (permalink)
Will's Avatar
You probably have oil in the intake and getting on your valves and spark plugs. Run a bunch of techron or other injector cleaner through it and see what happens then.
Will
Old 08-30-2006, 01:05 PM   #7 (permalink)
thanks for all your help
problems gandy dancer Twins Technical Talk 11 01-15-2008 02:40 AM
Has anyone had problems diagnosing tire problems? ohiorider Twins Technical Talk 1 07-18-2007 10:58 AM
Problems premier Speed Triple Forum 12 10-31-2006 10:34 PM
Having some problems Sprint Forum 8 09-07-2004 09:25 AM
problems with my tt Triumph SuperSports 4 02-24-2004 05:14 PM
