2000 TT600 air filter - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Old 08-28-2006, 11:24 AM   #1 (permalink)
Dig
Greetings gents,
I am looking to change the air filter on my 2000 TT600 and all I can find online are the K&N high performance types. Can anyone offer a source for standard OEM filters...or if I change to the K&N will I have to re-map? I would assume that an after market can with a K&N air filter would required a custom map but perhaps one of you can educate and enlighten me. Thanks in advance.
Regards,
Dan
Old 08-28-2006, 01:13 PM   #2 (permalink)
Official Leathers Tester
Favourite Bike: Very fast 675
Will's Avatar
You don't really have to remap for a K&N, but you will have to make adjustments in the fuel idle trim (CO) to keep from running too lean at small throttle openings. You will not see any performace gains from a K&N. Why can't you get the filter from a dealer?
Will
SponsorHouse profile
Old 08-28-2006, 01:21 PM   #3 (permalink)
Dig
Will,
Thanks for the fast response. The dealer I spoke to recently only stocked the K&N variety for some reason, probably because there is more margin. I do realize that I will not see any performance increase, that is actually why I'd rather go with a plain stock oem paper filter. Thanks again for the feedback....
-Dan
New Guy, with 2000 TT600 Back Woods Triumph SuperSports 8 07-23-2007 09:58 AM
uni verses KandN air filter air flow rays323929 Twins Technical Talk 3 01-31-2007 05:09 PM
2000 TT600 Problem crenmancmu Triumph SuperSports 3 04-18-2006 01:32 PM
2000 TT600 Questions? OzzyTT600 Maintenance & Workshop Talk 1 03-20-2006 06:55 PM
buying 2000 TT600.. what to look for? Triumph SuperSports 10 04-18-2005 11:49 AM
