Help: Brake light always on. - Triumph Forum: Triumph Rat Motorcycle Forums
Old 08-26-2006, 04:07 PM   #1 (permalink)
usnawolfe
It was brought to my attention yesterday by a kind police officer that my brake light was always on. I checked, and sure enough both the tail light and brake light bulbs were constantly lit. I'm guessing it maybe something to do with one of my brake controls, but I'm not quite sure how to go about figuring out if that's the case or not. I also thought it may be because the wiring between the brake light and tail light was mixed up, but since both bulbs are always on I don't think that's the case. Any help in this would be much appreciated.
Old 08-26-2006, 04:50 PM   #2 (permalink)
Favourite Bike: My 955 Daytona
doodledog's Avatar
Other Motorcycle: anything I can get.
spray you switches on the brakes with a bit of WD40, sounds like its notre seating when you let off the brakes :hammer:
I went to a restaurant that serves 'breakfast at any
time'. I ordered French Toast during the Renaissance
http://stickerchick.com/images/AD455-th.jpg
doodledog is offline   Reply With Quote
Old 08-26-2006, 08:29 PM   #3 (permalink)
Joe275's Avatar
had the same problem and it was the adjustment on the switch for the rear brake
"when i let off the throttle it gets all squirrely, so, i just stay on the throttle.."
Joe275 is offline   Reply With Quote
Old 08-26-2006, 09:32 PM   #4 (permalink)
Official Leathers Tester
Favourite Bike: Very fast 675
Will's Avatar
To expand on what Joe said- look at the right side peg and trace the brake pedal linkage. You will find a flimsy looking contraption with a wire that hooks to a hole in the pedal and a cylinder with a tin nut holding it to the bike. That is the switch, and all you have to do is screw the nut one way or another to change the point that the brake light goes on or off.
I hope that didn't just confuse things even more. It is a very common problem.
Will
SponsorHouse profile
Old 08-26-2006, 10:59 PM   #5 (permalink)
usnawolfe
Yeah, it was the rear brake petal. Thanks all for the help!
NB FEK installed, brake light works no running light pbcurran Club Cafe' 9 10-25-2007 03:20 PM
No brake light on '07 VWTim Speed Triple Forum 6 06-19-2007 03:54 PM
Integrated Tail light, brake light and turn signals?? stinger Sprint Forum 15 04-03-2007 10:21 PM
Brake Light? Roundman The Rocket Science Forum 1 09-07-2006 09:17 AM
Brake light - front brake Trudie Classic, Vintage & Veteran 8 03-16-2005 10:19 PM
