AdvanstarMotorcycleShowsBikeBanditTrident-Exhausts.comMotorcycle.com
Old 08-25-2006   #1 (permalink)
Finally received my cool little patent plate. Now ... where does it go, exactly? Also, how to affix? Rivets/glue? Pics would be greatly appreciated.
HooliganRandy is offline   Reply With Quote
Old 08-25-2006   #2 (permalink)
The front sprocket cover is the safest place. I removed the cover, then drilled tiny, and I mean very tiny, holes using the plate as a template. Then tap the screws in place. They protruded slightly from the back side, so I used a hot glue gun to help hold them in place. You could use different types of glue or epoxy to help hold it.
Joe-Dirt is offline   Reply With Quote
Old 08-25-2006   #3 (permalink)
And what's that plate then?
The cops told me I'm a squid
pete is offline   Reply With Quote
Old 08-25-2006   #4 (permalink)
It is a trademark plate that came on the old Triumphs.
Old 08-26-2006   #5 (permalink)
Nice can you get one that hasn't been pre drilled so you can glue it on ?
Don't let the B******s grind you down !
Dingle is offline   Reply With Quote
Old 08-26-2006   #6 (permalink)
Favorite Bike: '06 Triumph Speed 4
The rivets are key to the look, IMHO... If I were going to glue it on, i'd cut the screws/rivets and glue them in first, then glue the whole thing on...
Beer is proof that God loves us and wants us to be happy. -Benjamin Franklin
rustbucket is offline   Reply With Quote
Old 08-26-2006   #7 (permalink)
Yep, gotta have the rivets! If someone doesn't have a drill bit small enough, you could use a thumb tack or something to start the holes. All that is needed is a small pilot hole to start the screws in.
missing Trimph patent plate TOXO Twins Talk 17 06-21-2007 08:13 PM
Triumph vanity plate EnglishBeat Twins Talk 4 11-13-2006 05:25 PM
Triumph patent stickers..... KuzzinKenny Twins Talk 0 05-20-2006 08:10 PM
Triumph patent stickers..... KuzzinKenny Classic, Vintage & Veteran 0 05-20-2006 02:18 PM
How to remove patent plate? kawtoy Classic, Vintage & Veteran 6 04-19-2006 08:44 AM
