a couple questions on a tt600 - Triumph Forum: Triumph Rat Motorcycle Forums
Honda Powersports Ontario TourismMotorcycle.com
Old 08-23-2006, 11:06 PM   #1 (permalink)
xdvst8x
just picked up an 01 tt600.. guy said he was down shifting it.. and it loss power.. he stopped and it seemed fine.. went on home.. coolent was flowing out the tail pipe white smoke.. etc..
i got it from him.. started taking it apart.. cyclinder #3 the plug was melted.. no doubt there was detonation. and im sure the head gaskit is blown.
how could detonation occur in a stock bike like this? ive only seen it happen with turbos.??
second question.. what is the best way to drop the motor?
and what size are the motor mount bolts.. i count 3 on each side... is there a special tool needed?
Old 08-24-2006, 10:39 AM   #2 (permalink)
Official Leathers Tester
Favourite Bike: Very fast 675
Will's Avatar
Beats me why you would get a meltdown like that unless he tried to run it on some kind of bizarre campstove fuel mixed with gunpowder. Dropping the motor is fairly straight forward. If I remember right, the bolts are just a fairly large star drive. The more exotic tool becomes necessary when you want to align the motor in the frame. That tool moves a threaded insert that fits in the frame.
Will
SponsorHouse profile
Old 08-24-2006, 12:58 PM   #3 (permalink)
Favourite Bike: '06 Triumph Speed 4
FWIW - I saw an auction for a TT600 motor on ebay and posted a link earlier this week. That's always an option depending on how things work out... Best of luck!
Beer is proof that God loves us and wants us to be happy. -Benjamin Franklin
rustbucket is offline   Reply With Quote
Old 08-24-2006, 01:48 PM   #4 (permalink)
banda's Avatar
Extreme lean condition in the cyclinder? Clogged injector? Leak at the exhaust header? Leak at the intake?
banda is offline   Reply With Quote
Old 08-24-2006, 02:40 PM   #5 (permalink)
xdvst8x
::update::
took the head off.. 1 intake and 1 exthaust valve are now in 1 valve hole..
i think the head is fux0rd..... i found a new one for 1900$ *****... anyone know where a good used one is?
any ideas on what could have caused this... it was on cyclinder #3 counting from chain. everything else is fine..
i think id need a new piston too.. but sleeve looks good..
this sux.
Old 08-24-2006, 05:06 PM   #6 (permalink)
Will's Avatar
That used motor will probably be cheaper than a new head.
Will
Old 08-25-2006, 12:21 PM   #7 (permalink)
Here's the link - doesn't look like too much activity on the bidding. Maybe you can extract a gentleman's agreement from us RAT'ers not to bid it up!
Item #160021544896
Couple of Q's from newbie TT600 rider hammer784 Triumph SuperSports 7 07-28-2007 12:32 PM
Hello And a couple Questions Vaer Twins Technical Talk 6 11-27-2006 03:37 AM
couple of questions about "00 RS Olyrider Sprint Forum 8 10-09-2006 11:00 PM
Couple of questions.. GenIIIMrDuece Speed Triple Forum 2 10-02-2006 01:54 AM
A couple of new RS questions Solace Sprint Forum 15 03-11-2004 09:48 PM
