Recalls for the TT600 - Triumph Forum: Triumph Rat Motorcycle Forums
Honda PowersportsSportbikeTrackGearOntario TourismMotorcycle.com
Old 08-21-2006, 05:53 AM   #1 (permalink)
Hi All ,
I have a stock 2001 TT600 and i,m worried the 2 recalls for the clutch cable and plastic fuel tank connector haven't been done on it , how do i find out if they have can i just ring Triumph or can i get a dealer to check without it costing me .
Don't let the B******s grind you down !
Dingle is offline   Reply With Quote
Old 08-21-2006, 10:01 AM   #2 (permalink)
A dealer can run your VIN over the phone to check if any recalls were done on your bike.
The fuel connectors were a recall, but i think that the clutch cable was just a service advisory - ie replaced free if still under warrantee.
2003 Speed Four
BudGT is offline   Reply With Quote
Old 08-21-2006, 11:58 AM   #3 (permalink)
Official Leathers Tester
Favourite Bike: Very fast 675
Will's Avatar
There was also a service bulletin regarding the stator wiring harness. A dealer can check all that and perform the work for you if your VIN comes up needing it. I had a 2000 TT600 last fall that had none of that work done, and the dealership I frequent picked it all up without a problem.
Will
SponsorHouse profile
Old 08-21-2006, 03:09 PM   #4 (permalink)
Thanks for the info chaps , i,ll give the dealer a ring tomorrow and see what happens .
Recalls AAAANDYK Twins Technical Talk 1 10-16-2007 07:42 PM
Links for triumph recalls jeedizzle Triumph SuperSports 1 09-30-2007 08:02 PM
06 Sprint Recalls RickyT Sprint Forum 3 11-03-2006 04:38 PM
S4 Warranty Recalls Stampy Triumph SuperSports 6 06-25-2006 01:56 PM
recalls... Joe275 Triumph SuperSports 3 06-20-2004 07:11 PM
