oil/gas leaks from breather tubes? - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.comHonda PowersportsNew Bonneville
Old 08-20-2006, 05:13 PM   #1 (permalink)
My 2003 speed 4, (purchased new only a few months ago) has maybe 2000 miles on it. One of the hoses that doesn't connect to anything down near the shifter leaks a few drops of fluid every so often which smells like gasoline. Is this normal? The bike lives outside with a cover on it and I have only just noticed this problem in the hot summer weather.
It also seems to leak a drop or two of oil every so often from the other breather tube, but this only seems to happen when the bike gets hot enough for the fan to kick on.
Anyone have any solutions/suggestions? Or does anyone want to tell me not to worry about it and that it is completely normal?
Thanks in advance
nsb748 is offline   Reply With Quote
Old 08-21-2006, 04:54 AM   #2 (permalink)
Yes they are the breather pipes , if you fill the petrol to the brim it goes into the breather and comes out there . don't know about the oil one i suppose it,s the same and as long as you check your oil level regularly it should be ok .
Don't let the B******s grind you down !
Dingle is offline   Reply With Quote
Old 08-22-2006, 01:41 PM   #3 (permalink)
I've got a 2000 TT600 that I started a thread about oil coming out of one of the breather tubes. Check out http://www.triumphrat.net/modules.ph...53737&forum=27
smithtt is offline   Reply With Quote
Oil Leaks DGA Speed Triple Forum 15 07-10-2007 08:53 PM
Oil Leaks Poddy Sprint Forum 3 06-04-2007 12:12 PM
gas leaks retrobiker Classic, Vintage & Veteran 10 04-17-2007 04:27 PM
Breather hoses on gas tank........... speedydave Speed Triple Forum 12 12-21-2006 08:08 PM
gas seeping from my overflow tubes tjk2134 Sprint Forum 2 07-09-2006 11:06 PM
