After reading all the posts I could find on the subject, I pulled the IAC to check for cracks. When I lifted it out, all 4 vacuum lines stayed behind! They had hardened and split at the fittings. I replaced all 4 with standard vacuum line and it seems to have cured the problem (at least made a drastic improvement!)
Caution: the elbow at the throttle body and the nipple on the IAC are different sizes! Take both pieces to the parts store to find vacuum line that will work. A little lubricant on the 90's along with brute force and ignorance worked for me until I can get my hands on factory recplacements (about $16.00 each here:
www.bikebandit.com (click on OEM parts, they have awesome schematics!)
Anyhow, thanks for the help!
Scott
