TT600 rpm in 6th at 80 mph? - Triumph Forum: Triumph Rat Motorcycle Forums
New Bonneville
Ontario TourismMotorcycle.comHonda Powersports
Old 08-17-2006, 10:53 PM   #1 (permalink)
I'm wondering what rpm a TT600 should be turning at around 80 mph in 6th gear? I'm showing 7000'ish...
3MP
3madponchos is offline   Reply With Quote
Old 08-17-2006, 11:35 PM   #2 (permalink)
Yak
Yak's Avatar
That sounds pretty much correct. 70 mph in 6th is 5600rpm. I know because I had to spend 500 miserable miles at no more than that speed during my break-in.
2005 Triumph Speed Four - Yellow
Yak is offline   Reply With Quote
Old 08-17-2006, 11:45 PM   #3 (permalink)
That is about what i am showing on mine when at 80
pyro_ is offline   Reply With Quote
Old 08-18-2006, 05:34 AM   #4 (permalink)
Does anyone know what 70 mph and 80 mph would be in km/h. Can`t remember how to do that math.
TTfan is offline   Reply With Quote
Old 08-18-2006, 06:16 AM   #5 (permalink)
GoaticusMaximus
7k rpm = 80 mph (128.74 kph, 1.609344 kph = 1mph) in 6th gear (stock gearing) on my S4. Should be the same on the TT.
Old 08-18-2006, 10:44 AM   #6 (permalink)
Thanks. Don`t remember what mine does in 129 km/h but have a feeling that it would be higher than 7000, I have also wondered some times if mine is reving a bit higher than it should in that speed. If it does is this then a reaction of a wrong map or tuning on the bike?
Old 08-18-2006, 11:07 AM   #7 (permalink)
It also depends on your sprockets. If you change your sprocket sizes that can change what RPMs you are going to run at
Old 08-18-2006, 01:36 PM   #8 (permalink)
Thanks guys, that's just what I needed to know.
3MP
Old 08-18-2006, 03:00 PM   #9 (permalink)
Yes i know that and the sprockets are the original ones. Maybe it`s only me but sometimes after putting a new map on the bike it feels like the engine speed are different than it used to be. Don`t understand how that could be and it`s probably only my mind playing a game with me.
Old 08-19-2006, 12:58 PM   #10 (permalink)
I,m getting 6,700 rpm in 6th doing 80 is that right ?
On a totally stock 2001 TT600 .
Don't let the B******s grind you down !
Dingle is offline   Reply With Quote
MPH vs. RPM BonnieRob Twins Technical Talk 7 09-05-2007 12:19 PM
RPM to MPH ike9 Sprint Forum 5 03-28-2007 10:10 PM
RPM vs. MPH BadWolf Hinckley Classic Triples 8 07-15-2006 05:00 PM
America RPM AT 65 MPH dannsh Twins Talk 2 05-31-2006 03:39 PM
Bonneville MPH and RPM SFS Twins Talk 2 10-04-2005 01:04 AM
