Wiring GPS to TT600 - Triumph Forum: Triumph Rat Motorcycle Forums
Old 08-17-2006, 10:40 PM   #1 (permalink)
usnawolfe
Does anyone have any advice on the best way to power my Garmin 2820 while mounted to my 01' TT600? I've got all the mounts necessary (using a clutch RAM mount), but would like to hear any words of wisdom from people much smarter/more experienced than I concerning wiring a GPS unit to my bike's electrical system.
w.w.
Old 08-17-2006, 11:44 PM   #2 (permalink)
I have had one wired into mine before, make sure that you have a fuse inline with your wiring, even beter would be to have a relay on there so there is no power draw unless the bike is on
pyro_ is offline   Reply With Quote
Old 08-18-2006, 12:37 AM   #3 (permalink)
I have a fused power wire to hook up my Garmin GPS when I am taking trips. What is the pin configuration for your model GPS?
Which RAM components will you be using?
2003 Speed Four
BudGT is offline   Reply With Quote
Old 08-18-2006, 08:26 AM   #4 (permalink)
usnawolfe
I'm using the RAM clutch mount with a 3 in swing-arm attached to the RAM mounting bracket for the StreetPilot 2820. Here's the link to the power supply kit that I have.
http://www.cycoactive.com/gps/powint.htm (it's the GC12V26)
gps wiring/ mounting couchburner Club Cafe' 1 05-15-2007 09:59 AM
electrical/wiring question for GPS - help! Orpheus Twins Talk 7 04-28-2007 11:18 PM
Wiring diagram for a TT600? MickyC Triumph SuperSports 1 03-17-2007 01:06 PM
Help w/ GPS wiring usnawolfe Triumph SuperSports 5 09-12-2006 08:46 AM
Hard wiring a GPS to my 2003 Bonneville T100 Hogdad Twins Technical Talk 5 08-01-2006 11:25 AM
