i had this happen on mine, the speedo cable got pinched and rubbed off a bit. i took it to the dealer who immediately called triumph to make them aware of the situation, they told me to sodder it, (which seems to be holding) otheriwse theyll be buying me a new speedo if the problem persists.
look (facing the front of the bike) on the right side where the cable enters underneath the tank and check to see any pinching (i never noticed it, so i cant tell you exactly what to look for)
hope this helps!
"If you are not living on the edge, then you're taking up too much space."
