S4 fork springs - Triumph Forum: Triumph Rat Motorcycle Forums
New BonnevilleOntario TourismSportbikeTrackGearMotorcycle.com
Old 08-03-2006, 09:52 PM   #1 (permalink)
Last weekend I took my Speed Four out for the first time at the track. Despite the 100 degree temps, I had a blast. The Speed Four didn't give me any worries. I had a little trouble trusting the stock tires...but they performed just fine.
One negative thing I did notice was the too-soft fork springs. Even with the compression damping set at two clicks out, the front end had too much dive under heavy braking. I did the zip tie test, and I found the fork was very close to bottoming out.
What kind of aftermarket fork springs are you guys running for the track? I'm about 185 lbs.
chitownG60 is offline   Reply With Quote
Old 08-03-2006, 11:14 PM   #2 (permalink)
banda's Avatar
Try TT600 springs.
They're heavier.
Or use the calculator at racetech.com
banda is offline   Reply With Quote
Old 08-04-2006, 12:49 AM   #3 (permalink)
As long as it doesn't bottom out, it's okay. It's good to use the whole suspension travel.
But I agree S4 suspension is on the soft side. If anyone knows where to get linear springs (do Speed Triple springs fit?), let us know.
The cops told me I'm a squid
pete is offline   Reply With Quote
Old 08-04-2006, 03:14 PM   #4 (permalink)
Are you using the stock springs on the track? If they've treated you fine, I'll rest easy. But I wasn't pushing too hard last weekend, and I was surprised by the amount of fork dive.
Old 08-04-2006, 03:40 PM   #5 (permalink)
Yeah, I have stock suspension. Just get the preloads properly set and stiffen the shocks.
At least I (175lbs) got it decent by doing that. And was able to outrun new Fireblades, Ducatis and stuff so it can't be all bad
Old 08-04-2006, 04:26 PM   #6 (permalink)
Cool...I'll try dialing in the suspension a bit more. I currently have it set to the track settings listed in this forum. I might have to bump up the preload a little more...and maybe one less click out on compression. I have a month until my next trackday...so plenty of time to experiment.
Old 08-04-2006, 10:37 PM   #7 (permalink)
paintfumes
Where you at Mid-Ohio? If so I was too.
Old 08-06-2006, 11:38 AM   #8 (permalink)
No, I wasn't at Mid Ohio. I tracked at Blackhawk Farms. I should be there again the first weekend of September.
fork springs Cecfelix Hinckley Classic Triples 3 03-27-2007 08:52 PM
fork springs motorcycleboy Club Cafe' 4 03-09-2007 03:15 AM
Anyone want to trade me their S4 fork springs for my TT600 springs? BombFactory Triumph SuperSports 10 02-11-2007 11:46 PM
Fork Springs - What do I need? Tre900 Hinckley Classic Triples 6 06-17-2006 03:38 AM
Fork Springs ipg Tiger Workshop (archive) 6 03-03-2005 12:24 AM
