The original fuel fittings have a tendency to break however the ones fitted in the recall don't self seal upon disconnect
Best to have the fuel tank as empty as possible as a full one is quite a weight which won't help when it comes to carrying it. Also try not to rush too much when it starts dribbling fuel upon disconnecting the lines as you'll be more likely to drop it if you get in a panic! To be honest it's pretty straight forward so don't worry too much
I'll be upgrading to the metal ones when funds allow.
Airbox strap is the same as the battery strap so if yours has perished nick the one off the battery which will save you having to take everything off again when the you get the replacement :wink:
[ This message was edited by: Rik on 2006-07-25 05:35 ]
