The base plug of the CR9EK is just the plain old CR9E. the "K" make is a twin electrode plug, one on each side. You could get away with the CR9E if you got a case of the cheaps. I have no idea why Triumph would want to OEM spec a Twin electrode plug. If you want to upgrade you can go to the CR9EIX, which is a single electrode iridium plug wich will resist wear a little better, but at 2x the price its just a trade off.
2005 Triumph Speed Four - Yellow
