check the battery under load, you can do this with a load tester or using a voltage meter and cranking the bike with the ignition disconnected. the battery may appear fully charged at 12-13V but once you load it if it drops under about 6.5-6 its junk..
"when i let off the throttle it gets all squirrely, so, i just stay on the throttle.."
