Motorcycle.com
Old 05-19-2003   #1 (permalink)
Administrator
I went to Tulsa to visit one of the Triumph Dealers close to me (120 miles one-way).
He had a Black '02 S4 on the floor, new - never serviced. I spent some time checking it out. Very Cool.
However, I was a bit stunned by the Clutch Linkage mounted on the Engine Case. After spending some time comparing it to those on a Sprint ST, Sprint RS, and Tiger it appears that it is misaligned enough to cause premature wear on the clutch cable.
Has anyone else noticed this, or have done something to correct it?
Shawn
TriumphRat.Net
Shawn is offline   Reply With Quote
Old 05-19-2003   #2 (permalink)
Administrator
Shawn
TriumphRat.Net
Old 05-21-2003   #3 (permalink)
Shawn
misaligned how i have a 03 s4 and i'll look on mine
Pete
Old 05-21-2003   #4 (permalink)
Shawn
Pete
Old 05-21-2003   #5 (permalink)
I've seen what you're talking about on a friends S4. The bracket for the end of the cable sleeve holds the sleeve at a slight downward angle instead of horizontal, so the topside of the cable is rubbing against the edge of the sleeve. I'm not sure why they did it that way, I agree it seems like it would cause some wear on the cable. However, I'd be surprised if the lifespan of the clutch cable was decided by that particular detail. usually they shear at the lever right?
mbeebe900 is offline   Reply With Quote
Old 05-21-2003   #6 (permalink)
Speed four clutch cover FuryFour Triumph SuperSports 1 11-22-2006 12:48 PM
Speed Triple clutch cable on Scottius Sprint Forum 0 04-04-2006 12:49 PM
hydraulic clutch for speed triple? roadkill Speed Triple Forum 15 10-04-2005 11:15 PM
speed four clutch troubles Triumph SuperSports 11 05-24-2004 05:47 PM
Speed four Clutch Cable Triumph SuperSports 3 02-04-2004 10:45 AM
