» Links |
| Triumph SuperSports Triumph Four-Cylinder Enthusists: TT600, Speed4, and Daytona 600/650 |
05-17-2003
QUESTION FOR TT600 OWNERS/TECHS OR WHAT HAVE YOU. MY GEARCHANGE LEVER IS SECURED TO THE GEAR CHANGE SHAFT THROUGH A SPLINE SET-UPWITH A RELIEF MACHINED INTO FOR THE PINCH BOLT. MY PROBLEM BEING THAT THE BOLT WILL NOT PINCH ENOUGH TO ELIMINATE ALL FREE PLAY. DO ALL OF OUR TT'S DO THIS OR IS IT PECULIAR TO MINE ALONE .
thanks,
PAX
thanks,
PAX
05-18-2003
Official Leathers Tester
Site Supporter Team Owner Favorite Bike: Very fast 675
Posts: 3,610 Other Motorcycle: Very stationary Commando Extra Motorcycle: Hedge fodder Gixxer
I don't really understand the question- does the lever have some slop on the shaft and come clear off periodically? If that is the case, then you have a unique problem. If you find a little slack in the gearchange mechanism and a little drivetrain slack, then it is normal. The transmission is the one thing that I would like improved on my bike.
05-18-2003
05-24-2003
WILL,
FIRST OFF THANKS FOR ANSWERING.
SECOND OFF I THINK I GOT A LITTLE TO WORDY LAST TRY. I WAS TRYING TO SAY I'VE GOT SLOP IN THE SHIFTER
WITH THE PINCH BOLT AS TIGHT AS
REASONABLE FOR THAT SIZED BOLT .
ALSO,ON ANOTHER SUBJECT, I'VE BEEN WANTING TO FIND OUT
MORE INFO ON TUNEBOY SUCH AS AVAILABILITY IN THE STATES,COST, BENEFITS ,AND AVAILABLE MAPS. [I READ PREVIOUSLY IN THIS FORUM YOUR MENTION OF TBOY AND POWER COMMANDER]. THANKS IN ADVANCE,
PAX
05-24-2003
WILL,
PAX
05-24-2003
If your lever is loose when the pinch bolt is tight, try running a hacksaw down the gap the pinch bolt closes up with the lever pinched together. Usually this is caused by someone riding the bike with the shifter loose. When the shifter can move around it really gets loose in a hurry.
This goes back to my $200 dirtbike days. Anybody else have his problem with their 600?
Jeff
jeff tarlton
05-24-2003
Jeff
jeff tarlton
05-25-2003
World SuperBike Favorite Bike: 98 Thunderbird
Posts: 2,014 Other Motorcycle: 91 Zephyr 750
I remember this problem with worn out jap bikes, the trick was to insert a sewing needle between the splines and the lever.
05-25-2003
