If I recall, KeithU checked his valves twice, and never needed adjustment either time, so it is not unusual at all. I did mine and had one that was tight, and three that were at the tight end of the spec, so I adjusted all 4, so maybe next time I won't have to adjust any. It is important to log the clearances at each service for reference at future valve checks, so you might see if the shop has that if they didn't give it to you already.
