HELP!
I have a CA bike (one of the joys of living in sunny so Cal) and am in the process of removing the whole evaporative emissions system and could use some reference from a non CA bike but finding one of those is just about impossible here.
My questions about the non CA bike are:
1. Are the air bleed hoses from the idle control valve going directly to each throttle body? On the CA bike there is a connector between throttle body number 2 and 3 leading to the purge valve from the charcoal canister. I'm thinking that on non CA bikes that these bleeder hoses run straight to the throttle bodies individualy?
2. On the fuel pressure regulator located on the right end of the fuel rail, there is one vacuum or fuel line coming off of it? Where does this go on non CA bike?
3. On the ECM unit below the seat, there is one vacuum line coming off of it, where does this go on non CA bike?
4. Do non CA bikes have a rollover valve on the fuel tank overflow reflief line? For that matter, do the non CA bikes have two pressure relief valves
All of these things are diferent on my CA bike and I'm trying to revert back to the rest of the world standard. damn environmentalists. Don't they realize that this system does absolutely nothing since there are two fuel tank vent valves and one runs straight to the asphalt even on CA models. what a shame.
I would be grateful for any and all help on on this since my local dealer has rather limited knowledge of this or is simply refusing to help me. Photos would be especially helpful. I have a Triumph service manual but it is rather lacking in diagrams of the parts that I am referring to on rest of the world bikes. go figure.
happy riding.
