adjusting the preload is pretty easy on the Speed4, as there isn't any bodywork in the way. It goes like this; you'll be working from the left hand side, as the shock resevoir is in the way from the right. Gather; hammer(heavier the better), long, broad blade style screwdriver(long punch is nice)eye protection( from possible flying bits of screwdriver handle) and some silicone spray lube(WD40 in a pinch but there are so many better lubes available). Give a little shot of spray lube, aiming for the space where the spring meets the threaded collar. This will greatly reduce the friction between the collar and spring itself making the job a lot easier. With your srewdriver/punch, tap the top(locking) collar anti-clockwise a turn or so, leaving the adjusting collar free. You'll tap the adjusting collar clockwise to increase pre-load. Be careful to get the best purchase between the collar notch and screwdriver so as not to damage the notch. Try one full turn of the adjusting collar for a noticeable difference. Tap the locking collar down tight and enjoy your mechanical independance from the horribly overpriced dealer!
