Batteries can do that, so can a battery connection not tight enough. Also, check to make sure the tip over valve isn't cocked somehow. I finally just removed it from my yellow TT600, although is isn't a recommended modification. I had a couple getoffs on the bike, and it got knocked over while parked a few more times with no fuel leakage, but I can't guarantee the same results if you remove it from your tank vent line.
Will
