New bike wont start... - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com Classifieds!SportbikeTrackGearOntario TourismNew BonnevilleHonda Powersports
Old 06-05-2004, 09:05 PM   #1 (permalink)
Twice now my new speed four has failed to want to start up. It just turns over but no fire. It appears the kick stand no start switch is fouling me. Both times I ended up pushing the switch open and closed with a pocket knife to get the bike to fire. Once I'm done fiddling with it the bike fires right up. Doesn't matter what gear I'm and the kick stand is always up. Anybody ever had any problem with these? It's still under warrenty but I was toying with the idea of disabling the switch anyway... never needed one before.
Old 06-06-2004, 12:55 AM   #2 (permalink)
you could disconnect it as part of the troubleshooting process. I would suggest giving it (the piston that retracts into the switch body) a good shot of WD-40 or silicone spray; work the switch a few times and see if it still hangs you up. It's a good safety item, however; you wouldn't be anywhere near the first guy to crash after riding off with the side-stand down.
Old 06-06-2004, 01:27 AM   #3 (permalink)
Joe275's Avatar
i like the thing to be honest, makes it easy to shut down when i stop, but you do look like an ass when you pop it down in 1st to take off and the bike dies...doh!
"when i let off the throttle it gets all squirrely, so, i just stay on the throttle.."
Joe275 is offline   Reply With Quote
Old 06-06-2004, 01:55 AM   #4 (permalink)
Official Leathers Tester
Favourite Bike: Very fast 675
Will's Avatar
You look a lot dumber when you do manage to take off with the kick stand down. The first left is always a disaster. Not that I have ever done that... :thump: :blush:
Will
SponsorHouse profile
Old 06-06-2004, 02:10 AM   #5 (permalink)
that's just such a bad idea, ha, cause it'll happen someday, and i'd much rather the bike cut out than lose it in a turn, just like i did need something to remind me to take the lock off my front wheel before i tried to pull out of the parking spot, like 4 times
Old 06-06-2004, 01:33 PM   #6 (permalink)
Joe275's Avatar
i saw this from skyking for the wheel locks i guess........
http://skykingproducts.com/Merchant2...e=KA_ZX6_97_02
Old 06-06-2004, 10:44 PM   #7 (permalink)
Thanks for the advice. I'm going to wait and see if it does it again and play around with the switch some more to see for sure if that is it. I might bypass it temporarily as a troubleshooting tool but I'll keep it on there since it's part of the bike and I can make them fix it for free.
Yeah, the day after I removed it I'd be that guy rolling down the road with the stand down... and everyone following me waiting for that left hand turn... :-D
Old 06-07-2004, 01:30 PM   #8 (permalink)
And you're sure you didn't pull the gas lever when starting? Thus flooding it?
After twitching with the connection things had time to settle down and then it ran?
Old 06-07-2004, 07:03 PM   #9 (permalink)
I thought of that the first time it happened to me. So the second time I made sure I just hit the starter with no throttle at all. Still no joy. Of course, now it hasn't happened again. Maybe it was just a fluke. The bike hasn't seen the 600 mi breakin yet so perhaps it was just one of those little bugs to work out. If it happens again I'll call the dealer.
Old 06-07-2004, 11:33 PM   #10 (permalink)
Joe275's Avatar
wait, am i missing something or is it not possible to flood a fuel injected engine?
bike wont start eternity Twins Technical Talk 8 12-20-2007 04:05 PM
Bike Wont start jimmydean Speed Triple Forum 5 08-28-2007 05:24 PM
Bike wont start? HotSkeete Speed Triple Forum 3 09-05-2006 07:25 PM
Wont Start!! Classic, Vintage & Veteran 32 05-08-2005 12:18 PM
HELP. SPRINT ST WONT START Maintenance & Workshop Talk 6 03-28-2004 03:29 AM
