BikeBanditAdvanstarMotorcycleShowsMotorcycle.com
ShopTriumph.com
Old 06-05-2006   #1 (permalink)
Favorite Bike: Speed Triple
Catenaccio's Avatar
Other Motorcycle: Speed Four
Extra Motorcycle: CBR1100XX
I pulled the S4 out for a ride and noticed immediately that it was leaking gas on the cement. I traced the wet line back to a white plastic elbow under the tank. I'm afraid the elbow is cracked but can't tell for sure.
How difficult is it to remove the tank and replace the elbow? I might as well replace them all while I'm at it. (There is a red plastic elbow next to the white.)
What about brass elbows? Do they exist and how difficult would it be to convert from plastic to metal?
I live a good 3 hours from Vegas, the closest dealership. Is it necessary to send the tank away or is this a "do it yourself" project?
Lots of questions. Sure could use your expertise. By-the-by, does anyone have the tank section of a Triumph shop manual that could be scanned and sent to me? PM me if you have suggestions.
Thanks in advance. :???:
Catenaccio is offline   Reply With Quote
Old 06-05-2006   #2 (permalink)
Have you had the fuel connector recall done? Has the tank been off recently, as the O ring at the connector can often tear and leak.
Metal ones are available if you decide to go that route.
http://www.rideteamtriumph.com/images/TTFKD-1.jpg
2003 Speed Four
BudGT is offline   Reply With Quote
Old 06-05-2006   #3 (permalink)
Catenaccio's Avatar
No recall work. Guess I should check.
I haven't taken the tank off the bike. What metal elbows exist? Aluminum, brass? 1st of many dumb questions (Actually, the 5th dumb question but who's counting?) but would a metal fitting interfere with electricals, etc.?
Old 06-05-2006   #4 (permalink)
Catenaccio's Avatar
Found the recall number. Here's the info for anyone interested. (I know I am!)
Make / Models : Model/Build Years:
TRIUMPH / DAYTONA 600 2004
TRIUMPH / DAYTONA 955 1997-2004
TRIUMPH / DAYTONA T595 1997-2004
TRIUMPH / SPEED FOUR 2002-2004
TRIUMPH / SPEED TRIPLE 1997-2004
TRIUMPH / SPRINT RS 2000-2004
TRIUMPH / SPRINT ST 1999-2004
TRIUMPH / TIGER 1999-2004
TRIUMPH / TT600 2000-2003
Type: ANY
Recall Number: 04V156000
Summary:
ON CERTAIN MOTORCYCLES, THE FUEL CONNECTOR LINKING EACH OF THE FEED AND RETURN FUEL HOSES TO THE FUEL PUMP MOUNTING PLATE MAY FRACTURE FOLLOWING IN-SERVICE HANDLING.
Consequence:
FUEL COULD ESCAPE FROM THE FRACTURED BODY OF THE CONNECTOR ONTO THE ENGINE OR SIDE OF THE BIKE. FUEL LEAKAGE, IN THE PRESENCE OF AN IGNITION SOURCE, CAN RESULT IN A FIRE.
Remedy:
DEALERS WILL REPLACE THE CONNECTOR. THE RECALL BEGAN ON JULY 30, 2004. OWNERS SHOULD CONTACT TRIUMPH AT 1-678-854-2010.
Notes:
CUSTOMERS CAN ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION’S AUTO SAFETY HOTLINE AT 1-888-DASH-2-DOT (1-888-327-4236).
Old 06-06-2006   #5 (permalink)
Catenaccio
The replacement elbow is anodised aluminium. Anodised in red or silver to match the red/white colour coding on the female connectors in the tank. The female ones aren't changed unfortunately as some of us find they dont self-seal!
You may also have an outstanding recall on the shock absorbre top mount bolt. There is a small risk of it rubbing on the wiring loom.
good riding
Jon
Old 06-06-2006   #6 (permalink)
Favorite Bike: 00 TT600 Red/Silver
Other Motorcycle: 04 Yamaha YZ450f
Extra Motorcycle: 00 Buell X-1 Lightning
If you don't often need to remove the tank, brass hose barbs work well in place of the plastic or metal quick fits.
They're approx .50 each and last 1, 2, 3 years now w/o problem. Even outlasted my original motor.
The tank can stll be removed, just set aside as there is plety of hose to allow for that.
Josh
The reason Santa is so jolly is because he knows where the naughty girls live.
x1wagner is offline   Reply With Quote
Old 06-06-2006   #7 (permalink)
I have done this opn my S4. It is very easy. There are only 3 bolts holding on the tank. Then it just lifts off. You only have about 6" of play before you disconnect anything. Disconnect the fuel pump(white electrical connector) and two small vent lines first. Then disconnect the red and white fuel lines by pushing on the metal part of the connector. At this point you will probably be leaking fuel everywhere, but it seems like you already have that problem. The dealer should give you the replacements for free, just make sure you get the clamps. After replacing the connectors, reinstall the tank. This might be a good time to check your spark plugs and air filter.
petesgti is offline   Reply With Quote
Old 06-06-2006   #8 (permalink)
Catenaccio's Avatar
Sound advice from all. I truly appreciate your expertise.
Thanks!
gas leak!? 96SPRINTY900 T3 Sport / Touring Forum 1 05-11-2007 11:16 PM
Gas Leak? Joey5152000 Twins Technical Talk 5 04-22-2007 09:45 AM
Gas leak? CTF Twins Talk 6 03-07-2006 10:59 AM
Possible Gas Leak? dwheft Twins Talk 2 07-19-2005 06:04 PM
Gas Leak HELP! DahktahJay Sprint Forum 15 06-02-2005 09:27 PM
