AdvanstarMotorcycleShowsMotorcycle.comBikeBanditTrident-Exhausts.com
Old 05-30-2006   #1 (permalink)
Well i was going to try out swaping the stator and regulator rectifier today on the TT600 for one from an S4. it looks like the stator should fit no problem but it does not look like the regulator/rectifer will. The problem is that the S4 regulator has 2 connectors VS 1 for the TT600 and also the S4 has more wires 7 VS 5. What do you guys think should the stator from the S4 work correctly by itself and not burn up the regulator from the TT or not?
pyro_
pyro_ is offline   Reply With Quote
Old 05-30-2006   #2 (permalink)
i have used the stator from a TT600 in my S4 and it has worked with no problems. The S4 stator puts out more current so I don't how that would affect the regulator.
petesgti is offline   Reply With Quote
Old 05-30-2006   #3 (permalink)
yup that is what i am worried about, i dont really want to burn out my regulator with the extra power the stator would be putting out
Old 05-30-2006   #4 (permalink)
Favorite Bike: '06 Triumph Speed 4
If you can get a hold of a wiring diagram for the two it probably wouldn't be too hard to wire up - the bikes use the same ECU after all...
Beer is proof that God loves us and wants us to be happy. -Benjamin Franklin
rustbucket is offline   Reply With Quote
Old 05-30-2006   #5 (permalink)
pyro
the books shows the same wiring diagram for the Speed Four & TT600's after VIN 161333. If you PM me an email address I can send you details
JonG
Old 05-30-2006   #6 (permalink)
I don't think the regulator would be an issue unless you started adding accessories that drew more current than the regulator could handle. Why are you trying this? Just curious.
Old 05-30-2006   #7 (permalink)
trying to add those accessories since i use the bike for touring and also ride year round
Old 05-30-2006   #8 (permalink)
Official Leathers Tester
Favorite Bike: Very fast 675
Will's Avatar
Extra Motorcycle: A couple of 'em
For what its worth, I rode my stock TT600 with 105 watts of heated gear for a number of winters without any kind of problems.
Will
SponsorHouse profile
Old 05-30-2006   #9 (permalink)
I am looking at adding more than 110W of stuff that would be running all the time that is the problem hence the reason for trying to upgrade
Stator test correct? Will S4 stator work? redl1nerpm Triumph SuperSports 7 1 Day Ago 11:44 PM
stator wiring on TT600 pyro_ Triumph SuperSports 4 11-15-2007 02:15 AM
Stator mipstien Triumph SuperSports 5 09-08-2006 07:24 PM
stator shot PtboSprintSt Sprint Forum 9 09-08-2006 08:15 AM
Stator rj2006 Tiger Workshop 1 08-10-2006 03:19 AM
