Motorcycle.comBikeBanditAdvanstarMotorcycleShows
ShopTriumph.com
Old 05-27-2006   #1 (permalink)
After a ride this morning, I found that my rad fan wasn't turning on...engine temps were VERY high...and after I shut down, coolant spilled out the overflow.
I popped off the seat and found a connector on the rear right side of the bike was somehow disconnected. It doesn't have a mate plug...just plugs into a flat metal "bracket".
After reconnecting the plug to the bracket, everything seems to be ok.
Any insight on what the plug is actually for?
chitownG60 is offline   Reply With Quote
Old 05-27-2006   #2 (permalink)
A random guess: earth?
The cops told me I'm a squid
pete is offline   Reply With Quote
Old 05-27-2006   #3 (permalink)
That's my guess as well. Just wanted to be sure. I've never seen a ground cable with that type of connector. Not sure why Triumph would have done it that way.
Old 05-29-2006   #4 (permalink)
Favorite Bike: My 955 Daytona
doodledog's Avatar
Other Motorcycle: anything I can get.
If it conects to a flat metal braket the goes to the frame or is bolted on to it its an earth we do odd things here in the UK. :???:
I went to a restaurant that serves 'breakfast at any
time'. I ordered French Toast during the Renaissance
http://stickerchick.com/images/AD455-th.jpg
doodledog is offline   Reply With Quote
Old 05-30-2006   #5 (permalink)
The connector you're refering to, up high under the seat near the computer and the set of relays, is the connector for the dealers diagnostic machine. It's there just to keep from banging around until they need to plug it in. I believe it's also where a tune boy would plug in for map alterations.
-Nathan
ferrus is offline   Reply With Quote
Old 05-30-2006   #6 (permalink)
Official Leathers Tester
Favorite Bike: Very fast 675
Will's Avatar
Extra Motorcycle: A couple of 'em
That plug is not a ground. If it is what I am thinking, it is definately the plug for tuning. It connects to TuneBoy or the Triumph gameboy tool. The fin it attaches to is molded into the plastic undertray, so it isn't on a metal fin, it is on a black plastic fin. There is another grey connector that you might find under the airbox, usually down around the IAC Valve. That is a connector that gets used for some California emissions equipment and doesn't plug into anything on most bikes.
Will
SponsorHouse profile
Old 05-30-2006   #7 (permalink)
-Nathan
Now that makes more sense. If the connector was a ground...they type of connector wouldn't make sense.
What caused the rad fan to not turn on is still a mystery to me....but it's been running fine since the one incident.
[ This message was edited by: chitownG60 on 2006-05-30 16:46 ]
Old 05-30-2006   #8 (permalink)
When I originally saw the plug disconnected...that's exactly what I thought it was...the ECU tuning plug. But, considering the problem I had with my rad fan, I thought it could be a ground.
Rad issue boisespd3 Speed Triple Forum 3 09-18-2007 12:51 PM
Rad caps Greaser Hinckley Classic Triples 6 07-19-2007 08:26 PM
R3 rad cap (S3 rad cap hater). Avi8or The Rocket Science Forum 2 12-05-2006 02:13 AM
New Rad for the 900 rskeenan Trophy 6 07-14-2006 05:28 AM
Rad Guard Tankman Sprint Forum 3 05-11-2006 06:10 AM
