Motorcycle.comTrident-Exhausts.comAdvanstarMotorcycleShows
Old 05-12-2006   #1 (permalink)
BlackSpeedFour
Ok, so I removed the beanie from my S4 about a year ago. Last night I rode home in one of the worst rain showers I've ever ridden in, and my tach and warning lights started getting all screwy. My tach sat at 10k RPM for about ten minutes, and my low fuel light faded in and out.
I've seen several people put the gauge cover from a S3 on their S4. So my question is, how much did it cost to buy it, and do I need to modify anything to make it fit? And did you get it from a dealer?
Old 05-12-2006   #2 (permalink)
FuryFour's Avatar
$25 from dealer.
jsut bolts on to the back.
make sure you get for the correct year range (the ones for the new S3 wont work)
| 2006 Triumph Speed Four - SOLD |
| 2001 Triumph TT600 - SOLD |
| 2008 Triumph Daytona 675 - NEW |
| 1979 Honda CX500 - Old and Ugly |
| 2008 Dodge Ram 1500 Big Horn - Support Vehicle |
FuryFour is offline   Reply With Quote
Old 05-12-2006   #3 (permalink)
Favorite Bike: '06 Triumph Speed 4
I just got mine from the dealer yesterday - haven't fitted it yet though. I can give you the part number when I get home, because there are a couple of VIN breaks with slight changes to the design and different part numbers on that peice.
Beer is proof that God loves us and wants us to be happy. -Benjamin Franklin
rustbucket is offline   Reply With Quote
Old 05-12-2006   #4 (permalink)
ditchrat69's Avatar
I was quoted $39 from my dealer, which seemed really high. i have tried looking on Ebay, but with no luck.
I believe it is the 05 S3 that fits. same instrument panel
rustbucket- how much did you pay for yours?
Ditch
ditchrat69 is offline   Reply With Quote
Old 05-12-2006   #5 (permalink)
THe instrument cover is off the last model of S3 before the high cans. You can see the instrument pack looks identical take a pic of yours & wander round the bike shop till you see the same.
When fitting the cover you have to check the mounting bolts they go in further and one of them will touch the metal mounting frame transmitting vibes tou your expensive intrument pack.
If you cut 1 bolt shorter it fits nicely I just sawed of a bit. I think it was 8mm (about 1/3") but you need to see the problem & do it by eye as you can end up with not much thread.
Cheers Jon
Old 05-12-2006   #6 (permalink)
BlackSpeedFour
My S4 is a 2003, so it probably takes the older S3 cover.
Does the 2005-06 S4 have the same instruments with the shift light as the newer S3?
[ This message was edited by: BlackSpeedFour on 2006-05-12 13:16 ]
Old 05-12-2006   #7 (permalink)
I was charged $23 for the cover...
Old 05-12-2006   #8 (permalink)
FuryFour's Avatar
no, its still the same as all other s4 models
Old 05-12-2006   #9 (permalink)
Official Leathers Tester
Favorite Bike: Very fast 675
Will's Avatar
Extra Motorcycle: A couple of 'em
I am pretty sure the one that fits also fits a 2000 to 2004 S3, not the newer one. The newer one uses the same clocks as my new bike. The S3, S4, and TT600 uses the same clocks.
Will
SponsorHouse profile
Old 05-12-2006   #10 (permalink)
ditchrat69's Avatar
man. I am getting hosed. I guess that's why they are "stealers" :-D
Ditch
GSG clutch cover and stator cover sliders! HiVel Speed Triple Forum 5 01-09-2007 10:04 PM
Speed 3 Gauge cover PragB Triumph SuperSports 12 07-23-2006 03:56 AM
speedo / gauge cover on Ebay... dml955i Daytona Deliberations 3 02-02-2005 06:35 PM
speedo / gauge cover just listed on ebay! dml955i Speed Triple Forum 1 02-02-2005 06:11 PM
Want to remove flyscreen?I have gauge cover. teacherkeith Speed Triple Forum 10 01-25-2005 11:40 PM
