On 2006-05-11 11:29, srebrenica wrote:
...and it won't start. She's turning over and i hooked up jumper cables so i know its not the battery. People have told me check the pepcock or empty the old gas out of the carb but the 2001 TT600 is fuel injected so i don't think thats the problem... (pls forgive the ignorance). Anyway, any other suggestions for trouble shooting this? Should i empy the gas and run some fuel injector cleaner? Would really like to get out this weekend and ride!
What is the latest on this? There is no petcock, of course. If you didn't stabilize the gasoline last fall, you may have some clogging in the injectors. Fuel injector cleaner is a good idea, as is pulling off the fuel tank, emptying the fuel, and putting in some fresh gas.
