BikeBanditMotorcycle.comAdvanstarMotorcycleShows
Trident-Exhausts.com
Old 05-09-2006   #1 (permalink)
Ok now Im thinking of a chopped cf silencer. i want it shorter because they are just too long. What I would like to know is if its ok to just take apart a silencer, cut and put it back together?
thanks
also is cf hard to cut??? given that it is supposed to be very strong.
Dirt286 is offline   Reply With Quote
Old 05-09-2006   #2 (permalink)
FuryFour's Avatar
i've seen it done..so can't be too hard.
it's probably going to sound like @ss though
| 2006 Triumph Speed Four - SOLD |
| 2001 Triumph TT600 - SOLD |
| 2008 Triumph Daytona 675 - NEW |
| 1979 Honda CX500 - Old and Ugly |
| 2008 Dodge Ram 1500 Big Horn - Support Vehicle |
FuryFour is offline   Reply With Quote
Old 05-09-2006   #3 (permalink)
Favorite Bike: My 955 Daytona
doodledog's Avatar
Other Motorcycle: anything I can get.
tOLD YOU CAN DRILL OUT THE POP RIVETS, ANGLE GRIND TO SIZE PUT END ETC BACK ON AND RE POP RIVET IN PLACE SOUNDS SIMPLE BUT GRUSOM TO ME, AND AS FURY SAYS YOU AINT GOING TO KNOW HOW IT SOUNDS UNTIL ITS DONE AND YOU CANNOT GO BACK, I AM THINKING ABOUT TRYING IT WITH A CHEAP ZX6R CAN FROM EBAY BUT NOT SURE I HAVE THE BALLS TO TRY! :hammer: PS sorry for shouting i am a bit deaf
I went to a restaurant that serves 'breakfast at any
time'. I ordered French Toast during the Renaissance
http://stickerchick.com/images/AD455-th.jpg
doodledog is offline   Reply With Quote
Old 05-09-2006   #4 (permalink)
I did it for a Micron ZRX 1100 can. Very easy, just like doogledog said, just pull it apart (the Micron can is bolted together) angle grind a bit off, weld and/or rivet it together. Didn't take half an hour.
At least for me the sound is very good. Discreet, but throaty on low revs, but goddiggety the devilish scream from hell above 9K :lgh:
The cops told me I'm a squid
pete is offline   Reply With Quote
Old 05-09-2006   #5 (permalink)
yeah i didnt think it would be too hard but let me ask you this, do kawasaki pipes have the same mounting points as the S4 or are you not using that bracket that holds it up from the passenger footpeg?
Old 05-10-2006   #6 (permalink)
The pipe connection was the same but i had to bend the band a bit to make it fit the footpeg connector.
To check which pipes fit, LeoVince have excellent technical drawings (LeoVince part finder) Look for flange type 12A, they'll all fit TT600, S4 and Daytona pipework
Old 05-10-2006   #7 (permalink)
doodledog's Avatar
The Remus can on mine was a ZX6R can and used the same mounting points I had to make the holes a little bit longer on the bracket that bolts to the can to make the hole to the hanger fir, 5 min job and just bolted into the same place as the OE can :hammer:
Old 05-13-2006   #8 (permalink)
ezride's Avatar
Agreed about the length of most pipes on this bike (including the stock pipe). They seem to hang out the back.
Triumph (fake) CF can. Super short. Very loud. :-D If only I could fix the low end fussiness with the open pipe....
ezride is offline   Reply With Quote
Old 05-15-2006   #9 (permalink)
I have a s/s ZX6R end can made by CARBON CAN COMPANY, cost 100 squid off ebay, bolts straight on, no mods needed. Sounds a bit raspy but otherwise OK. I don't think it matters how short your can is as the exhaust is just too ***** long. Can this be cut?
johnny5 is offline   Reply With Quote
Old 05-16-2006   #10 (permalink)
doodledog's Avatar
Yes it can as above I saw a guy on a bike meet the other day with a cut ZX6R can SS remus like mine he said it took a couple of hours but would be quicker now he knows how, he used a hacksaw but agreed a angle grinder would be better if it did'nt overheat and discolour the steel, sounded good but illegal. :hammer:
Chopping the kink off the Bonnies pipes? 5bassman Twins Technical Talk 24 11-20-2007 10:39 AM
Exhaust mods/Slip-on exhaust DaytonaBabe Triumph SuperSports 5 06-11-2007 12:59 PM
Daytona 955i Exhaust on 2001 S3? '02-'04 Exhaust on '01? OldSkoolFool Speed Triple Forum 7 05-14-2007 08:24 PM
Jardines Exhaust & Exhaust Flange Covers 3xdope The Rocket Science Forum 1 09-21-2006 06:24 PM
CHOPPING A CAN WITH PICS doodledog Triumph SuperSports 8 06-03-2006 01:41 PM
