The owner's manual doesn't tell you this, but if you hold the select button (or maybe it is the reset button- it has been a while since I played with it) down for five straight seconds, it switches the unit readout. You can have MPH and degrees F, MPH and degrees C, or KPH and degrees C.
It is exactly the same instrument panel as the TT600.
Will
