Old 05-19-2004   #1 (permalink)
I was looking underneath the airbox on the left side of my S4 and noticed a rubber tube, not connected to anything & plugged with a rubber plug. At first I thought it should be attached to something, but after looking at the service manual Purge/Idle Air Control exploded view (p 8.5) it appears that it should be that way, but could someone tell me what this tube is?
Now I'm just curious, because I can't find a description in the manual, just the picture. Thanks.
Zane
2003 Triumph Speed Four
2006 Honda RC51
zaner30 is offline   Reply With Quote
Old 05-19-2004   #2 (permalink)
Official Leathers Tester
Favorite Bike: Very fast 675
Will's Avatar
It is the airbox drain. If you ride in the rain, the water has to go somewhere, I guess. The plug is so that you don't suck up a lot of junk into your engine. Beats me how it stays a drain if it is plugged, but that is what it is, a far as I know.
Will
SponsorHouse profile
Old 05-19-2004   #3 (permalink)
djr
because there would only ever be tiny amounts of anything there under normal circumstances. If you drop the bike and oil gets into the airbox it drains from here as well and you would not want the oil draining from there as you ride, it would spray all over your rear tyre!
David
My Photo Album
My Tiger pages
djr is offline   Reply With Quote
left side low side swingarm damage? NathanielM Speed Triple Forum 10 09-12-2007 08:02 PM
Can't find Airbox breather tube?!? Jack_T_Bird Hinckley Classic Triples 7 04-19-2007 04:43 PM
AI removes LEFT tube but what is the RIGHT tube for? ocguyocguy Twins Technical Talk 2 01-26-2007 11:10 PM
Noise from left side Freddie The Rocket Science Forum 11 12-22-2006 08:20 PM
TBird Airbox Drain tube/plug mecscc Hinckley Classic Triples 5 03-07-2005 09:22 AM
