BikeBandit
Old 04-23-2006   #1 (permalink)
Banana650
Took the D650 for a good run yesterday. Noticed a couple of things that I'm really not sure about.
- when I rolled off the throttle, the vibes through the footpegs were really noticeable - is this usual?
- bit more serious - when I got into the high nineties & above - the front end really started to shake (or bounce as it wasn't really wobbling), if I was braking I'd call it chatter - this can't be normal.
Any ideas?
Carole
[ This message was edited by: Banana650 on 2006-04-23 10:10 ]
Old 04-23-2006   #2 (permalink)
Official Leathers Tester
Favorite Bike: Very fast 675
Will's Avatar
Do you have an unbalanced front tire? That is the first place I would look for something like that.
Will
SponsorHouse profile
Old 04-27-2006   #3 (permalink)
Banana650
Will
Thanks for the advice - the front wheel was out of balance. The reason? I'd put Ultraseal in the front tyre (as I've done on 3 previous bikes) for peace of mind in case of a puncture. Turns out, this was throwing the front wheel out of balance at high speed.
Just had to pay to get the stuff out again, but bike's going fine now.
Carole
Bouncy Tachometer? Billdozer Twins Technical Talk 25 11-13-2007 10:14 PM
Front highway pegs SPTRIP Twins Technical Talk 1 12-20-2006 08:28 AM
Front end is getting really bouncy Smitty Speed Triple Forum 5 05-22-2006 11:32 AM
New pegs!!! Hinckley Daytona Deliberations 1 07-29-2005 10:08 AM
Bouncy Tach Needle - Carb Sync??? jasmail Hinckley Classic Triples 20 12-08-2004 09:31 PM
