Old 04-06-2006   #1 (permalink)
sorry all, there was some discussion of this recently but i can't track it down...i have a LOT of vapor from the bike when its a bit wet/cold(under 40f)...i'm taking the bike in to remap to a new can i bought and thought if anyone had info they could look at this issue while i'm there (since the dealer is a ferry ride and 30 miles for me...). Lemme know! TIA.
hardboild is offline   Reply With Quote
Old 04-07-2006   #2 (permalink)
Official Leathers Tester
Favorite Bike: Very fast 675
Will's Avatar
Extra Motorcycle: A couple of 'em
Mileage? Is it just when the air outside is cold and damp, and/or the engine is just warming up? I don't see how that is a problem, unless it is smoking all the time.
Will
SponsorHouse profile
Old 04-08-2006   #3 (permalink)
conditions:
wet or damp/under 40-45 or so degrees: thing is like a fog machine, pretty embarrassing (especially surrounded by other winter ferry bikers) but burns off once on the road and engine temp is around 150f.
I talked to cyclebarn about it and tech said it was the stock can collecting moisture...but then i heard something about a problem with the crankcase breather oil & the airbox--in any event, i need to get my new can tuned today, i'll let you know what they come up with.
Old 04-08-2006   #4 (permalink)
Hardboild
If the vapour is very white it could be oil. Put your glove in the smoke and smell it does it smell oily?
It can collect in the airfilter box and gives heavy white smoke when the engine is cold/tepid. This happens when the breather pumps oil to the airbox it also shows as an oil-leak from the left engine side [where it has dripped from the airbox!].
The best way to check for this is to remove the tank and airfilter look in the back of the airbox. An easier way of (almost) checking is pulling the breather pipe from the right crankcase to the airbox to see if it is oily, if you pinch the clip with pliers it comes off & goes on easily.
I hope it is just condensation
Jon
Old 04-08-2006   #5 (permalink)
That sounds like the cause. Mine does that on cold mornings until it is warmed up. :wink:
Joe-Dirt is offline   Reply With Quote
Old 04-09-2006   #6 (permalink)
Triumph_Dude
Yep, same here- white vapor/ smoke until it's warmed up. For whatever reason, it seems to have more vapor than most other bikes. My wife's SV hardly has any.
Old 04-15-2006   #7 (permalink)
took her in today to get a remap for my new can, showed photos of the vapor to the mech...checked everything out and said it is just the way she is. so i guess i will live with it...beware those behind me as i lay down the screen...feel bit like a WWII destroyer in a convoy tho...
c'est la vie!
Has anyone ever fitted a Vapor on their Bonnie? SteveRocket Twins Technical Talk 15 01-21-2008 12:24 AM
Vapor Lock or what? NinjaRAT Sprint Forum 26 12-29-2007 08:48 PM
What's up with this vapor lock thing? cafetbird Hinckley Classic Triples 12 10-16-2007 01:48 PM
What the best exhaust for a TT600 Berkdiggler Triumph SuperSports 1 11-30-2006 10:53 AM
Exhaust Vapor TBirdG Tiger Chat 7 04-25-2006 10:54 AM
