Okay, I've owned my '02 TT600 since April '03. For the past two years, it has had an oil leak that I've been off and on chasing down. The dealer replaced the vent valve, the sump pan gasket, and the shifter seal (twice). The bike still leaks oil, and it appears to be coming from around the shifter seal.
My question: Could something have gone wrong internally (bad bushing, etc) to allow oil to build up behind the shifter seal in a way it should not? I can move the shaft back and forth about 3/8 of an inch, but I've noted that there is also play in the shafts on other bikes. I did put the bike down hard on the track once, breaking the end of the shift lever, but the leak existed before that.
The shop mechanic had a nice insight when he suggested that the internal pressue of the transmission is too high due to inadequate venting, but that doesn't help me solve my problem.
Believe me, I've done my homework on this one, and it's been at least a year since I last brought up my problem. Just hoping someone might have new insights
Thanks,
Kurt
"I have kicked myself mentally a hundred times for that stupidity.... I didn't understand then how foolish quick assumptions like that are. Now we are on a twenty-eight-horse machine and I take the maintenance of it very seriously." R. Pirsig, Z&AMM
