A lot of us think the clutch cable and its routing are the worst thing on the speed four!!
You can try putting a "hole grommet" in the eye of the wire cable to to protect it.
One owner successfully sleeved the cable (I tried that and failed!)
You can also run it further inboard and rebend the cable loop.
All of these work to some extent, personally I am getting a different cable made up and will keep you all posted if it works
Jon :???:
