Daytona 650 Yellow Waring light on the Tach - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Motorcycle.com Classifieds!New BonnevilleOntario Tourism
Old 02-08-2006, 10:57 AM   #1 (permalink)
davehenricks
I keep coming up with a yellow warning light on my 2005 Daytona 650 Tachometer. Somebody told me it could be low battery voltage and to put it on a trickle charger. Has anybody experienced that also. :???:
Old 02-08-2006, 11:03 AM   #2 (permalink)
don't know, but putting it on a trickle charger can't hurt it
but if you have been riding often it shouldn't run the battery down
..................RUSS........................
http://i56.photobucket.com/albums/g1...aking-done.gif
hinkleyboy is offline   Reply With Quote
Old 02-08-2006, 11:08 AM   #3 (permalink)
Official Leathers Tester
Favourite Bike: Very fast 675
Will's Avatar
Is that the check engine light? It could be all kinds of things. If it is the red low oil pressure light, you really want to shut down the motor right away, but the yellow one is the ecu's way of telling you it has a fault code stored in it. If it stays on past three heat cycles, probably best to get it checked out. If you disconnect the battery and then reconnect it, that will sometimes light the trouble light for a while. Hope this helps.
Will
SponsorHouse profile
Old 02-08-2006, 11:25 AM   #4 (permalink)
i have been having battery problems on mine. i am now on my third battery and that's what it shows on mine. dealer can't find anything draining it, but about every three months i'll get to where i have to push it off if i let it sit more than three days. i think the light just adds to my decor now; all i have to do is run it good for a day or two and the light goes away. if you're worried then by all means get it checked out. but experience dictates for me that it's just a weak battery.
gerinipus is offline   Reply With Quote
Old School Yellow Light - 6V or 12V? Cafe Con Leche Club Cafe' 5 08-24-2007 10:01 PM
Tach light out ResearchRat T3 Sport / Touring Forum 8 07-03-2007 10:33 AM
Yellow engine light Timan Speed Triple Forum 5 04-02-2007 09:56 PM
YELLOW lensed indicator warning light? DrPat Twins Technical Talk 2 01-16-2007 05:00 PM
My fuel waring light has fixed itself! Aussiebikerdave The Rocket Science Forum 2 07-17-2005 07:02 PM
