idle set screw - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Motorcycle.com Classifieds!Honda Powersports
Old 02-03-2006, 08:25 PM   #1 (permalink)
ello again there is a thred on tt600.org about the idle set screw where abouts is it located on the bike as mine idles very low and cuts out
cheers
russ
..................RUSS........................
http://i56.photobucket.com/albums/g1...aking-done.gif
hinkleyboy is offline   Reply With Quote
Old 02-04-2006, 05:15 PM   #2 (permalink)
Official Leathers Tester
Favourite Bike: Very fast 675
Will's Avatar
There is an idle set screw? I know there is a way to set the idle speed using TuneEdit, and there is a throttle position sensor in the FI system. Maybe there is a throttle stop somewhere on the fuel injector body assembly, but I have never looked for it. My guess is that you have a synchronization problem or something like that. That is where I would look before looking for a way to prop the throttle open a little with an adjusting screw.
Will
SponsorHouse profile
Idle mixture screw help?! ttbonnie Twins Technical Talk 4 08-18-2007 09:33 PM
Is everyone else having to mess with the idle screw? Sluggo Twins Talk 26 05-14-2007 09:41 PM
Idle mixture screw Blacklion50 Maintenance & Workshop Talk 1 04-11-2007 11:02 AM
Idle set-screw? and Idle rate at start MontrealMike Triumph SuperSports 2 05-01-2006 06:37 PM
Idle mixture screw, in or out Lovechops Twins Talk 5 10-10-2005 01:27 PM
